Help! Found a blown a gasket!!!
Posted by Tims A on April 08, 2008 at 13:13:12 from (66.66.151.107):
I have pulled the oil pan on the A to remove the dents and clean it out. I see the oil pump has a piece of gasket about 3/16 long sticking out the side (right side). Have I been running with no oil pressure? Can I remove the cover with the pump in the tractor and replace the gaskets? Manual mentions setting gear end-play with gaskets, how do you measure this? I assumed my gauge has been busted, its 1/4 full of oil.
Tim
