Re: My Findings on Actual Hydraulic Output PSI, Maybe Low?
Posted by old on April 08, 2008 at 13:17:07 from (4.244.57.243):
In Reply to: My Findings on Actual Hydraulic Output PSI, Maybe Low? posted by charles todd on April 08, 2008 at 12:48:08:
Yes you should be able to use a different or reset your relief valve. As far as GPM it depends on what your going to use it on. If its for a loader the higher GPM can cause big problems that would make it unsafe to use and flip your tractor
