Re: My Findings on Actual Hydraulic Output PSI, Maybe Low?
Posted by the tractor vet on April 09, 2008 at 06:12:02 from (76.212.231.52):
In Reply to: Re: My Findings on Actual Hydraulic Output PSI, Maybe Low? posted by mkirsch on April 09, 2008 at 05:16:58:
How do you know it is the relief ??? did ya run all the test while it was hooked up to a flow rater and at proper operating temp. Did you plumb in the flow rater to by pass the system relief ??? Ya can not find the problem with just a gauge and by checking thru the remotes.
