Re: Replacing F20 felts
Posted by Ron Weber on April 09, 2008 at 12:15:29 from (216.11.184.10):
In Reply to: Re: Replacing F20 felts posted by Nebraska Cowman on April 09, 2008 at 07:54:07:
First, I buy hard felt from a bearing company; it retains the seal better. Then, I put heavy grease on them before assembly so that they prevent oil from seaping through. After that, I make sure that they are packed tight around the shaft to help with the seal. Then, when I put new brake shoes on I cut shallow grooves on an angle towards the outside of the drum in a way that if the grease did get on the drum surface it would be moved out of the drum when the tractor is braked going forward. I use a dremel to cut in the grooves. Ihave had extremely good luck using this method over the years; never had a problem once I fixed it this way. Gook Luck!
