Re: Super A - 140 belt pulley
Posted by Daniel H. on April 09, 2008 at 19:35:39 from (66.226.34.159):
In Reply to: Super A - 140 belt pulley posted by orangepower on April 09, 2008 at 19:06:34:
There is a cover above the PTO shaft. Thee tractor has to have a bevel drive gear on the end of the transmission shaft to run the belt pulley. If you pull a belt pulley, be sure to get the gear and the shims from the donor. You will need a new large o-ring (358208R1) to seal the belt pulley housing. Lubricate the o-ring good before installation.
