Re: farmall M carb trouble
Posted by tj in iowa on April 09, 2008 at 19:50:19 from (67.1.120.35):
In Reply to: farmall M carb trouble posted by lucas jones on April 09, 2008 at 07:14:46:
Check that rubber tip on the needle, if someone pushed on it when attempting to adjust the float then there could be a dimple or ring in the rubber and not allowing it to seal, I have seen this happen, the old style metal ones will not do that. If this is the case you will probably have to replace the needle and seat.
