have you tried a GOOD napa or similar parts supplier on your loadstar? if you want i will try to find it at work, let me know if you want me to try. i might need to know which distributor and engine. you can email me if you want.
on the 606, the gearshift is between your legs, right? i bet it is susceptible to the same issues as the H M, and so on. you might try pulling the shift lever out and using a prybar to align your trans in neutral, and then inspect for wear on your shifter before reassembling. it might need to be built up and ground to fit. many posts on this for H and M in the archives. hard shifting could be partially caused by a worn lever or a lever missing its pivot pin. could be (more likely) other issues too.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
