Re: Farmall Super A or AV
Posted by Hugh MacKay on April 10, 2008 at 09:34:08 from (209.226.247.37):
In Reply to: Re: Farmall Super A or AV posted by Walter Buller on April 10, 2008 at 09:23:05:
Walter The only real difference between Super A and Super AV are; the SAV had 9x36 rear tires, 5:00x19 front tires and they all had the heavy duty square front axle. Gear ratios were the same on both.
If you truly have a SAV I think it should indicate that on the serial tag. Having never owned a Super AV I'm not certain how the tags differ.
