Re: H farmall brakes
Posted by Randy-IA on April 10, 2008 at 14:45:05 from (207.177.83.247):
In Reply to: H farmall brakes posted by Booth2563 on April 10, 2008 at 13:41:38:
Hi , It could be oil soaked , it could be it's had so much grit and dirt in it over the years the brake drum is worn down to small , it could be the linkage is worn out inside . Have you taken it apart to look inside ? Are you talking about the pedal adjustment or the slack adjustment at the bottom of the cover ?...Randy
