to get two way hydraulics from them, you need a two way open center spool valve, either single, double or triple depending on how many remotes. route one of the hoses from the belly pump, lets say the front one on the left side to the in on the spool valve, route the return to either the belly pump drain plug, i use a tee here with a cap so i can drain the pump to change fluid when necessary, or you can tee in to the fill pipe. to operate, you wire the control rod in the full back position, then use your spool valves to control the cylinder.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
