Re: farmall super c
Posted by CNKS on April 10, 2008 at 17:55:51 from (216.144.104.128):
In Reply to: farmall super c posted by big ddd on April 10, 2008 at 17:25:37:
Carb is probably too lean. Since the main jet is not adjustable, your float level may be too low. Your replacment carb sounds like an aftermarket, Zenith should be correct from the factory. You could have rebuilt your old one for much less money. I don't have a service manual for a Super C. Float height for a Zenith carb on the Super A and C is 1 5/32 with the throttle body upside down. Measured from the top (bottom) of the float to the gasket. I don't have the spec for a Carter carb.
