Re: single plow for super A
Posted by Haas on April 10, 2008 at 18:25:37 from (12.65.0.76):
In Reply to: single plow for super A posted by RJV on April 10, 2008 at 17:28:21:
The Super A plow is much heavier built than the Cub. The cushion springs on the hitch are about twice as big. I'm surprised you were able to bolt the Cub plow up on the super A, as I thought the plow beam on the Cub plow was shorter, but maybe not. The Super A plow works the same as the Cub, only it's bigger. You turn the drawbar around and mount it on the front holes in the final drives. I think you do the same on the cub. The Super A plow has a rod that goes from the Draw bar to the RH front rockshaft to work as the dept control. It moves the drawbar up and down, controlling the tilt of the plow. However, that part is frequently missing. I used a Super A plow (I now have a 140 with Fast Hitch Plow) for years without that adjusting rod. I just set the draw bar with the bolts in the brackets to the lowest setting. Doing that takes a couple of passes to get going, but it will work.
