Posted by Janicholson on April 11, 2008 at 16:44:03 from (64.83.197.92):
In Reply to: H motor rebuild posted by landlord7012 on April 11, 2008 at 15:42:36:
I would drill a series of tangent ooles (about 1/4"drill) to remove the top of the piston. Then use a muffler chisel to cut down the inside of a drilled hole to split the piston (90degrees from the wrist pin) to collapse it. Then remove the piston. The sleeve can be expanded so much from corrosion of thepiston rings, that removal can crack the block casting under the thin sleeve. JimN
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
