Re: Distributor Cap/Coil Orientation
Posted by Bob M on April 11, 2008 at 18:46:50 from (69.205.125.108):
In Reply to: Distributor Cap/Coil Orientation posted by Tom B. on April 11, 2008 at 14:27:31:
Tom - As the others mention the Delco vertical distributor is an aftermarket replacement for the original magneto.
The Delco distributor works just as well as the horizontal IHC distributor. Just be aware when you are buy tune up parts (cap, rotor, points, etc) they are different from - and NOT interchangeable with - those for the IHC distributor. So be sure you get parts for the Delco unit!
