Re: farmall super c
Posted by Andy Motteberg on April 11, 2008 at 19:10:12 from (4.143.217.157):
In Reply to: farmall super c posted by big ddd on April 10, 2008 at 17:25:37:
I had a problem like that on my H before, I had to switch to copper core spark plug wires and non-resistor type spark plugs, I used Autolite 3116. After I did that I changed my timing a little and now my tractor works perfect. Make sure you do not have "automotive type" plug wires.
Andy.
