Posted by Tab on April 12, 2008 at 05:07:07 from (4.252.38.223):
That 140 that I recently bought is running like a top. The transmission only had about a quart of gear oil still in it, and I think it had never been changed.I refilled with a fresh gallon. The engine oil had some water in it, but you couldn't see it untill after draining into a pan. It was "gray" colored. This came from the tractor being outside, at some point with an open exhaust pipe in the rain. Final-drive units must have been close to dry, because I put a quart of gear oil in each one, and it never ran out of the plug hole. I'm sure the hydro fluid needs changing, and I'm going to do that today. Lifts don't leak down, and are stable. But front lift jerks a little when you raise it(on the way up). Carb needed re-building, so I did. Engine doesn't smoke any, and I see no leaks. Looks like a fairly new radiator on it. Anyway, thanks for All your help with the tractor issues that I've had.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
