Re: H Farmall radiator
Posted by jal-SD on April 12, 2008 at 07:21:02 from (208.53.222.162):
In Reply to: H Farmall radiator posted by Booth2563 on April 12, 2008 at 07:14:27:
Under the frame, above the nuts. Be sure to grease the bolts w/water resitant grease, either you or someone else will THANK YOU for this sometime in the future when the radiator has to come off. Those bolts ALWAYS rust & in MHO, taking them off is the most miserable job there is when you are working on an H. (My $0.02 worth. jal-SD)
