Re: SMTA Brakes
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Bob M on March 07, 2000 at 18:04:07 from (152.163.213.52):
In Reply to: SMTA Brakes posted by mike on March 07, 2000 at 15:40:04:
Replacing SM brakes is straightforward: First unscrew the actuating/adjusting rod from the yoke that goes into the brake. Now remove the long bolts holding the brake cover to the transmission. Then simply pull the cover off, rotating as required to clear the drawbar support bracket on the axle. One of the friction disks will be left on the splined half shaft - the other will be inside the cover, underneath the center actuating disk assembly. Lift the actuating disk out of the cover to get at the other friction disk.
Simply reverse the procedure to reassemble. Sounds a lot more difficult than it really is...
A couple of notes: 1 - While you've got everything apart, remove the springs that hold the two halves of the actuating disk together and separate the two halves. Make sure the ramps and balls inside are free of rust and junk, then lube with a little dry graphite before putting back together. 2 - Wire brush the transmission half shaft splines to get them clean, then lightly coat them with Never Sieze before reinstalling the brake disks. 3 - Make sure the friction disks and mating iron surfaces are free of grease and oil before putting back together
Post A Followup
: Re: Re: SMTA Brakes
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
