Posted by Haas on April 12, 2008 at 13:54:19 from (12.65.30.232):
In Reply to: 140 PTO shaft posted by orangepower on April 12, 2008 at 08:50:15:
It's been a while. I hope I'm telling you correct. To remove the PTO shaft, you have to take the PTO unit off the tractor. You will then see the gear mounted on the inside end of the PTO shaft that drives the shaft. As I recall, the shaft comes out to the outside, so you have to take the gear off first. Don't try to drive the shaft out after taking the gear retainer bolt out of the inside end of the shaft. The woodruff key that keys the gear to the shaft will catch on the bearing race and prevent the shaft from coming out. As I recall the gear is not a press fit on the shaft, so it's not difficult to get off, but a gear puller would be best. Once the shaft is out, the bearings and spacer should more or less just fall out. Then you can use something (I use a large socket of the correct diameter) to drive the old seal out.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
