Posted by John Franklin on April 12, 2008 at 16:07:48 from (76.106.36.255):
Put a working battery in my Super A today and got the tractor running. I turned on the lights and the ammeter showed a discharge. I polarized the generator per John T's instructions:
To Polarize the Generator, first temporarily dead ground the Gens Field post to case/frame, then momentarily flash jump a wire from the Cutout Relay or VR's "BAT" terminal over to its GEN (or ARM) terminal and you ought to get a small spark. Same things accomplished by momentarily flash jumping a hot wire (BAT terminal on Cutout Relay or VR or starter post etc) direct to the Gens ARM post to get the spark.
I was getting 6.3 volts at the battery with my multimeter but when I throttled her up, the voltage didn't increase. It' stayed at 6.3 volts and the ammeter never showed a positive charge. It just stayed on zero. I even had the lights on for quite a while and still showed no positive charge on the ammeter.
I then temporarily grounded the generators's Field post to the case to see if it showed a charge then. But it didn't. After that, I just removed the generator and voltage regulator and brought it back with me. I'll have it tested at shop that specialized in that. Hopefully they'll find the problem. I don't think the problem is in the ammeter.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
