Re: 140 PTO shaft
Posted by Red Mist on April 12, 2008 at 17:03:24 from (208.61.168.150):
In Reply to: 140 PTO shaft posted by orangepower on April 12, 2008 at 08:50:15:
Are you sure you have to remove the shaft to replace the seal? I don't think so.... Drill a couple of holes in the old seal and screw in a couple of wood screws. Carefully pry out the seal using the wood screw heads as a means of gripping the seal. mike
