Posted by Janicholson on April 13, 2008 at 14:45:31 from (66.173.50.96):
In Reply to: Magneto and Cranking posted by Tims A on April 13, 2008 at 14:18:53:
If the magneto switch is in the off position, it is effectively shut off. No harm will come to it. The harm from disconnected plug wires is caused by the excess voltage taking any possible path to ground. This can begin the process of leaving carbon tracks, or short circuit paths for the High Voltage. Just leave the switch in the stop position, and crank as needed. Do not crank more than 30 seconds at a time, then leave it cool for 2 minutes. Starter motors have a 20% duty cycle or so, and will overheat if run for long periods. JimN
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
