340 utility mystery plug
Posted by tesmith66 on April 14, 2008 at 05:56:51 from (130.76.96.19):
On the bottom of the tractor, RH side, centered with the hydraulic filter cover and inboard about 6 inches (about halfway between the front and middle tranny drain plugs) I found a piece of wood hammered up into a smooth hole approximately 1/2" diameter. Hytran (well, water, then a Hytran/water mix) came out after I pulled it. Is this hole supposed to be there? Obviously the plug isn't factory, but if the hole is, what do I plug it with? I find no mention of it in either the operator's manual or the I&T manual.
