Re: Farmall 350 battery
Posted by Janicholson on April 14, 2008 at 09:04:11 from (199.17.6.122):
In Reply to: Farmall 350 battery posted by mickey350 on April 14, 2008 at 08:37:04:
without knowing more, I will give the following:
If it has three cells (three caps on the cell coverings that either pry or screw off, it is a six volt. If it has two big square covers, covering 3 openings each it is a 12 volt.
The reality is that it came from the factory as a 6 volt if it is a gas tractor, and 12 volt if diesel. Both of these were positive ground systems (not the same as modern cars)
If you know the difference between an alternator, and a generator by looking at it, you can be assured it will have 12v negative ground (99% chance)if it is an alternator.
If it has a genreator, it will have an external device attached near it, or in the wiring to it for control (either a cutout relay, or a voltage regulator) We can help dramatically if we know what you have with certainty. Google images of Delco farmall Generators. The fifth image I found was typical. Then look at delco SI 10 alternator images. they do not look the same. Give us a photo, or tell us what you have. Putting the wrong battery in it the wrong way always lets the smoke out of the parts. JimN
