Re: Heating time
Posted by tractorsam on April 14, 2008 at 13:48:49 from (71.7.203.35):
In Reply to: Re: Heating time posted by Kristof on April 14, 2008 at 13:32:03:
If you're wanting to run kero you should have shutters on there otherwise you'll have a hard time getting it warm. Unless you're working that tractor at least fairly hard you'd better stick to gas unless you like engine rebuilds. If the engine isn't hot enough the kero will wash the cylinder walls and dilute the sump oil. Just driving it won't get it warm enough. Hope this helps, tractorsam
