Posted by rust collector on April 14, 2008 at 14:33:23 from (130.18.53.203):
In Reply to: Farmall H question posted by farmerwannabe on April 14, 2008 at 14:02:18:
If you are talking about the original belly lift for the "H", then yes, pipe plugs are the accepted practice. Leave the lift control rod in a neutral or float position (all the way down) and no power is used other than to turn some gears in oil. If the lift rod is pulled, the hydraulic oil will be pumped against the pressure relief and you should hear some lugging of the engine. This will not hurt short term, but could result in leaks in seals or fittings if left long term. Can also add quick connects if replacing the loader or other attachments regularly.
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea
... [Read Article]
Latest Ad:
[More Ads]
