Super-H Hyd lift will not hold up kelly Loader
Posted by VA Gasman on April 14, 2008 at 14:43:50 from (208.103.140.174):
Moved 3 logs this AM with Kelly loader on H worked fine. Moved 2 bales of hay worked fine. Went to move it later on and bucket will not stay up. Cylinders leak down. Will lift fine but will not stay in up position. Just as soon as you stop the lifting sequence it will start slowly down. Not as fast as if you have released pressure. What should I look for ?
Thanks, Randy
