Re: IH 784- help please!
Posted by JimB2 on April 14, 2008 at 15:55:25 from (99.241.179.24):
In Reply to: IH 784- help please! posted by racraig9137 on April 14, 2008 at 11:14:37:
Craig,
1)There is an interlock switch on the clutch so clutch must be held in before starter will engage. Although most people have disabled the switch. SET PARKING BRAKE & HOLD BRAKE PEDALS DOWN. Put REV/Neutral/HI/LO Transmission lever in Neutral position. Lever closest to fender.
2)Set throttle (lever at right side of steering column) to about 1/4 open.
3)In middle of panel below steering column and just above transmission cover is a lever that should have Decal markings on the panel as STOP START RUN but must likely the decals are worn off. STOP is all the way to the bottom next the transmission cover, RUN is all the way to the top and START is about 1/4 the way up. So put in the START position and turn the ignition key to the right to engage the starter. If tractor is warm you don't have to put it in the START position just go directly to RUN. If weather is cool or first start of the day then use the START position and once engine starts let it run on START position for about 30 seconds and then bring lever up to RUN position.
4)IF it is really cold like below 32F then there is an Ether injection bottom on the opposite side of the dash panel to the starter switch. Give it a momentary shot of Ether will starter is rolling the engine. To much Ether will cause the engine to lockup and if this happens DO NOT attempt to start tractor for about 30 minutes.
DISCLAIMER:
I AM NOT RESPONSIBLE FOR ANY DAMAGES OR INJURIES INCURRED.
JimB
