Re: Heating time
Posted by RAW in IA on April 14, 2008 at 18:15:32 from (12.215.87.124):
In Reply to: Heating time posted by Kristof on April 14, 2008 at 13:12:55:
Unles you have a blockage of the radiator or low water level it will not move , likeVito said. The guage is at the coolest part of the cooling system. The only time I ever sy dad's C get warm at all was ne day when I was mowing and the water level was low. By then it had burnt the valve comver gasket!
