Re: Farmall M Brakes... big job or not?
Posted by HENRY E NC on April 15, 2008 at 15:06:40 from (216.119.6.172):
In Reply to: Re: Farmall M Brakes... big job or not? posted by Learning2Pull on April 15, 2008 at 14:19:05:
If all your bnolts are loose on the drawbar it is a vry simple job. First, disconnect the long return springs, then the adjustment spring. Remove the brake actuating lever and remove the woodward key from the shaft. NOW, remove the top drawbar nut and loosen the bottom one to make room for pan removal Now take a 9/16 socket ant remove the pan around the brake which will slide off of the brake shaft. Clean out the area, replace the brake pads abd reinstall in reverse. Not a bad job if you can get the drawbar loose easy. I had to cut one drawbar nut off and ended up replacing the whole 8" by 7/16 bolt because it was rusted almost thru. Henry Could take as little as an hour per side.
