Re: 656 Utility Hydralic Issues
Posted by TractormanNC on April 16, 2008 at 04:45:48 from (209.42.180.140):
In Reply to: 656 Utility Hydralic Issues posted by redpuller on April 15, 2008 at 19:42:52:
Did you replace BOTH pumps? Front one works the steering and remotes, rear "piggyback" pump works hitch. If the seal ring between the clutch housing and rear frame is leaking air (common problem) quick fix is to over fill the trans by about 5 gallons. Ran one for years like that.
