Re: Super C: Symptoms of broken axle or other major problem
Posted by mkirsch on April 16, 2008 at 09:12:34 from (64.80.108.52):
In Reply to: Super C: Symptoms of broken axle or other major problem posted by Bongo on April 16, 2008 at 06:12:41:
As with 99.9% of these tractor problems, "Take it apart, see what's wrong, and fix it," is the order of the day.
At least from your description, it does NOT sound like a broken axle, at least. A broken axle would leave you unable to drive the tractor at all.
Contrary to the other reply, I would NOT recommend continuing to use the tractor until you can determine what's wrong. What may be an inexpensive easy fix now could turn into a nightmare later.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
