Re: Model M Farmall
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Phil Auten on March 08, 2000 at 04:33:32 from (206.175.72.226):
In Reply to: Model M Farmall posted by Carl on March 07, 2000 at 18:05:33:
Carl,
I'm pretty sure the Char-Lynn PS unit uses the hydraulic reservoir to hold it's fluid. Use Hy-Tran or equivalent in the hydraulic reservoir. The M's originally had a dipstick attached to the cap for the reservoir, but most of them are long gone. Bob M's suggestion works, but I like to fill mine by adding oil until the cylinders work properly and then add 1 more quart. That's worked ok so far for me. Once you get it full, you can make your own dipstick and just hang it in a convenient place on the tractor so it'll be there when you need it.
Enjoy your M,
Phil
Post A Followup
: Re: Re: Model M Farmall
