Posted by Mike CA on April 16, 2008 at 10:45:06 from (214.1.211.251):
In Reply to: H wire diagram posted by JThomas on April 16, 2008 at 08:51:41:
Bob M said: Mike - Unfortunately a 4 position switch cannot easily be adapted to do what you propose (would require a major internal modification of the switch to accomplish)
Instead probably the easiest solution to do what you propose is to wire the front lights normally. Then wire the rear light thru a separate on-off switch.
To your other question, with a voltage regulator there is no need for manual charge rate control (the regulator does this for you). Rather the L and H positions simply become two alternate "off" positions for the lights.
hmm, so there is no need for the 4th position then, or even the third?
Were 3 position switches available in 1944, or just 4?
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
