Re: M brake adjustment
Posted by Michael Soldan on April 16, 2008 at 12:37:29 from (24.235.58.254):
In Reply to: M brake adjustment posted by HENRY E NC on April 16, 2008 at 12:29:22:
If that adjustment isn't doing anything they are likely worn beyond adjusting.Loosen the jamb nut at the bottom of the pans and turn the screw in a turn at a time and see if that gives you brakes. Pull a pan off and observe, maybe oil leaking through the seal has affected the brake...8 studs and its off, tha actuating arm comes off with the brake pan.
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
