Posted by Dan Bear Kelley on April 16, 2008 at 17:04:54 from (140.32.120.188):
I'm looking at replacing the hydraulic valves on my the Farmhand F11-B loader on my M. I've got 2 spools and I want 3. The extra will be for my 3-pt hitch (when I get around to buying it). The old valves are pretty worn out, so there is no real point in messing with them.
I'm getting myself all wrapped around the axle on terminology, and I'll bet the solutions are simple. Could you all please back-check what I've kinda figured out?
Three-Way: That's like up, neutral and down for the bucket or hitch, right?
Four-way: That's up, neutral, down and float for the main loader arms, right? What's float?
Open Center, Power Beyond and Closed Center: Open center is where the hydraulic fluid just circulates from inlet side to outlet side of the valve unless it is needed to actually power something. Closed center is used with variable pumps or with a separate unloader valve. Power beyond is used if I need additional valves in the system--like if I were to add some kind of jaws to my bucket or retractable scarifiers to my box blade in the future. I've got a Prince PTO-mounted pump, so I should go with open center for now, right?
Finally (sorry this is so long a post!), my PTO pump completely blocks my use of the PTO. I've seen PTO shaft extensions. What's your opinion on these? Are they safe? Will they wear out my PTO bearings faster? If I added an overrunning clutch in addition to this extension, wouldn't the whole thing kinda get wobbly?
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
