Re: oil pump or rebuild kit model 424 gas
Posted by Edpap on April 16, 2008 at 19:49:52 from (74.33.236.203):
In Reply to: oil pump or rebuild kit model 424 gas posted by Kirk n Va. on April 16, 2008 at 13:37:44:
Hello Kirk,
The rule of thum for minimum oil pressure is 10 psi per 1000 rpm.
does the engine smoke? your idle pressure is low but high idle is ok. If it realy bothers you I would pull the oil pan and take a look. maybe you can put a kit in the oil pump and slip in some new rod bearings and bring you pressure up you can look up the engine parts you want at abcrepairparts.com
Good luck Ed
