Re: H farmall oil leak
Posted by Wayne in MN on April 16, 2008 at 20:34:39 from (68.119.27.241):
In Reply to: H farmall oil leak posted by Booth2563 on April 16, 2008 at 17:44:35:
Both transmission drive shaft & PTO drive seals are located behind the belly pump.
Remove the pump & the PTO seal is right there where the pump drive connector was located. Put the transmission in reverse & lock the brakes. Use a bar or pipe wrench to unscrew the drive lug, lefty-loosey.
Remove the 3 cap screws & the housing comes off with seal attached. Replace the seal & gasket, replace the 3 cap screws, screw the drive lug in, righty-tighty, & you are done. Some oil will leak thru the bearing while you are replacing the seal.
Transmission drive is similar but you must remove the drive shaft coupler to get at the seal. Tip: when the nuts are off the tapered bolt, hold the coupler drive with a pipe wrench & turn the tapered bolt to loosen. Don’t try to drive it out or damage will happen.
