Re: 2606 brake balls
Posted by GordoSD on April 17, 2008 at 07:44:07 from (66.115.200.140):
In Reply to: 2606 brake balls posted by bc on April 17, 2008 at 06:41:26:
Why not plane the housing down .075 or so?
Those balls have to travel up the ramps to spread the discs. I can't imagine that they are getting to the ends of the ramps and the discs not quite a ways apart. Problem has to be in the outer surfaces (steel) where contact is made.
Also get a round wood rasp and scuff those discs up. Also scuff up the steel surfaces with a 40 grit flap wheel. New highly polised balls, and some polishing on the ramps with die grinder and sanding drums also helps.
You know you are about done when you can remove and install the whole shebang in about 5 minutes.
Gordo
