Re: I'll tell you what, them rear wheels are heavy!
Posted by F-Dean on April 17, 2008 at 07:50:09 from (67.72.98.95):
In Reply to: I'll tell you what, them rear wheels are heavy! posted by Mike CA on April 17, 2008 at 07:43:07:
Mike,
Get the "water" out of the tires unless you are going to plow with your H. Removing the water and putting new tubes in the tires will save a lot of problems. Uneven amounts of water MAY make it unsafe in road gear!
Today's Featured Article - Tire Fluids - by Curtis von Fange. It came as a surprise. The tire on the tractor needed to be pulled off to get to the brakes for service. The tires were blocked, the rear end raised on jacks, the lugs loosened and the tire loosened from the hub. Then, as the big lugged circle of rubber slipped off the last wheel stud it became apparent that there was more there than just an empty tire. Four hundred pounds of rim, tire, and fluid dropped to the ground like a sack of wet cement. Fortunately the installer jumped out of the wa ... [Read Article]
