Re: I'll tell you what, them rear wheels are heavy!
Posted by ScottyHOMEy on April 17, 2008 at 08:03:18 from (71.241.213.254):
In Reply to: I'll tell you what, them rear wheels are heavy! posted by Mike CA on April 17, 2008 at 07:43:07:
Be careful with what you're callin' water there, Mike.
If all these tires spent all their time in sunny Southern Cal, it might be just water.
If it is just water or water and beet juice, no real harm to be done.
If it's antifreeze (doubtful but possible), you need to be careful with disposal for all the obvious reasons.
If it's water and CaCl (far more common than antifreeze), there's two points. One is, be caeful where you dump it or even do the work of unloading it. It'll kill anything green and keep anything green from growing for quite a while. The other is to wash down anything that the stuff tuches really well when you're done, as it will corrode just about anything it touches. Disposal of CaCl is easy if you know somebody wiht a dirt or gravel drive. It'll kill any weeds growin' in it, and will help hold the dust down for a while.
