Re: To he who soldered his Touch Control strainer
Posted by tractorsam on April 17, 2008 at 15:42:27 from (71.7.203.35):
In Reply to: To he who soldered his Touch Control strainer posted by P and R Pete on April 17, 2008 at 13:02:07:
I would be he! I had to solder one on a 140 because I accidentally stuck a screwdriver through it in my attempt to remove it. I can't rememeber exactly what I did but I'm pretty sure I used some material from a brass strainer screen from a sediment bowl as patch material as I actually had a hole rather than a tear. If you can get the ends to mate up well you might get away without any extra material. I'm pretty sure I used a soldering iron to melt some solder and then used the iron to coerce it into the mesh (I was holding the screen above the iron). Because I was installing a patch I first secured the ends of the patch and then did the edges and went back and tidied up the ends. I hope you find this helpful, tractorsam
