Re: I'll tell you what, them rear wheels are heavy!
Posted by Mike CA on April 17, 2008 at 21:18:37 from (67.125.138.135):
In Reply to: I'll tell you what, them rear wheels are heavy! posted by Mike CA on April 17, 2008 at 07:43:07:
geoge said: Well you do not ask questions untill after you do something.[/quote:f3f54d1630]
Completely wrong. Absolutely wrong. I ask questions, then give whatever it is a shot, then ask clarifying questions to make sure I understand it.
geoge said: You do endanger your children and yourself[/quote:f3f54d1630]Wrong again.
[quote:f3f54d1630="geoge"]flying only mean you went up in an airplane sometime, it does not mean you have any mechanical ability
I haven't posted my resume on this forum. But again, you are wrong. Yes, I went up in an airplane sometimes. 4000 hours in fact. And what about on the ground? I work on the aircraft. I'm not an engine or structural mechanic, but I have turned wrenches with them over the years. I was also a Quality Assurance rep for several years. So I learned attention to detail. In fact, my meticulous attention to detail sometimes annoys my friend who works with me on the tractor because I have to check, and re-check my work to make sure it's as good as I can get it.
[quote:f3f54d1630="geoge"]I will personally call the cops on you.
Wow, personal threats. I like it. This is turning into a real forum after all. :roll: I'm sure the cops will drop everything and come chase down the Farmall going 3 miles an hour down the neighborhood street based on your urgent tip. Good luck with that.
