Re: Yet another question.. hydraulics is the topic once agai
Posted by glennster on April 18, 2008 at 14:33:14 from (76.223.243.231):
In Reply to: Yet another question.. hydraulics is the topic once again. posted by IHMANKY on April 18, 2008 at 14:15:55:
the outputs on the belly pump are npt pipe thread. either 1/2 inch or 3/4 pipe, i'd have to go out and look. if i understand what you are doing, you want to plumb in a double spool valve for two outlets. if they are two way hydraulics, you only need one output from the pump, pipe it to the valve, return goes either to the drain plug on the belly pump or to the fill pipe with a tee. the rear output on the left side was for the rear cultivator, there would be a restrictor valve in the line so the front cultivator would drop first , then the rear.
