Posted by jd b puller on April 18, 2008 at 15:45:26 from (24.225.90.65):
In Reply to: E85 and Farmall H posted by 160dan on April 18, 2008 at 14:48:52:
You'll likely need to rejet your carb, as the fuel/air ratio is about 8:1 vs. 13:1 for gasoline. All the other comments about Ethanol eating rubber should be heeded as well. If it sits in the tank long, it will draw moisture from the air and create this slimy stuff in the tank... You'll also use more of it than straight gas. If you can buy it for 2 bucks a gallon, it will far offset that, but if you're not careful it will either run really lean or not at all..
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
