Re: E85 and Farmall H
Posted by Pete in Holland, MI on April 18, 2008 at 19:44:08 from (24.247.182.120):
In Reply to: E85 and Farmall H posted by 160dan on April 18, 2008 at 14:48:52:
E85 may be an alternative to gasoline, but it is not a good value. I experienced a mileage drop from 18 to 14mpg when I ran a couple tanks thru my truck last summer. There is less BTU's per gallon, so for the same horsepower needs, you will go thru more e85 than gasoline. Thus, my cost per mile jumped up.
Now, another question: Being e85 is mostly corn alcohol, why does it's cost basically follow the ups & downs of gasoline? Shouldn't it's price be based on something different than the cost of a barrel of oil ? Something's fishy here.
