IH 966 cluth adj hyd clucth thow out bearing turns all the t
Posted by Jim Kreis on April 18, 2008 at 21:16:03 from (209.173.254.189):
iH 966 trator clucth hdy asst can not see how the throw out bearing will not turn all the time because the asst is spring loaded no mater what i do to adj it is spring loaded linkeage pulled up all the way it will always put some presurer on the trowout bearing it turns all the time had the flywheel turned it is step down . any help thank you ....
