Re: converting super h to 12 volt
Posted by Brownie450 on April 19, 2008 at 04:00:06 from (216.51.158.251):
In Reply to: converting super h to 12 volt posted by Andrew Kappers on April 18, 2008 at 15:35:06:
Like Gene said--get a generator from a 450D--looks the same--then get the 12-volt regulator to go along, & you're ready to go. Same wiring harness--ready to go.
