Re: 400 pros ,cons?
Posted by Bob Frey on April 19, 2008 at 15:54:08 from (74.46.104.232):
In Reply to: 400 pros ,cons? posted by littlemackinawfarmall on April 18, 2008 at 20:57:55:
The power steering setup that will fit an M would work fine with a 400. If you can find a safety/ relief valve with the power steering outlet you would only need the power steering motor and use the tractor hydraulic system for the source. If your tractor has a TA it can frequently be a problem. I need to fix the TA on my 400 but really don't need to use it so it's hard to justify the work and the money to make the repair. The live power and hydraulic is nice to have on the 400.
Bob
