Re: Super A
Posted by Janicholson on April 19, 2008 at 15:56:25 from (64.83.197.92):
In Reply to: Super A posted by roger cox on April 19, 2008 at 15:02:32:
A stuck intake valve can do it, as can a bit of moisture in the distributor,or mag cap, causing a cylinder to fire on the wrong cycle. If the engine trys to start, and spins backward, it can also do it. JimN
